TV box needs reboot every time & won't record
I've always had issues where my recordings freezes on occasion but recently it's stopped working properly.
When we go onto Netflix sometimes it kicks us back to the menu. This has been happening on and off for over a month.
Since the weekend, the box won't record anything at all, whether on or off at the time of the recording. It just says 'failed to record'. Although it does still display the message that it is recording on the TV screen.
Every time we turn the box back on after being on standby, it shows a black screen and needs rebooting. Sometimes we also can't play recordings without rebooting a second time, they just show a black screen when selected. Oh and on demand services won't work either.
I'm reluctant to do a factory reset because my toddler's favourite films are on the box and we don't want to lose them.
Any suggestions please?
Sorry, but as it's not working with a soft reset you will need to go deeper to resolve.
if the box does need replacing you will lose your recordings anyway.
Try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
Try the Factory Reset keep recording option. You won't lose recordings with this option.
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
Hi Eversham1
Try The maintenance reset as advised.  If that fails to resolve then the full factory reset from the settings menu is the only option left to try.
