Talktalk TV box upgrade
1 REPLY 1
Visitor
Yesterday I received an upgrade for the youview box. However the new one doesn’t have the record function as my previous box had. I use this function a lot so would miss not having this. Is there a TV box that still has the recording function, and how much would it cost to upgrade to this box? If I don’t upgrade and continue using my old box, would it stop working at some point when all the new boxes are introduced?
You have received the correct box, the Lite box.
You do not have the TV charge applied or use any TV boosts.
The box was sent for free. If recording functionality is important, you can still use your existing box for recordings. If not wishing to use the new Lite Box as your main box, you can use this in another room or pass it to a family member if not required.
The Lite box will receive future updates and does support the later Amazon Prime and Now TV apps.
If a plus box is required, this can be purchased via our customer service teams.
