Youview Box Problems
DandD
My Youview box has suddenly gone a little crazy, it only records the first 18mins of a programme, won't let me change channels (I have changed the batteries in the remote!) or look at the guide,or pause a live programme, I have to turn it off at the back & restart, its ok for a while, but as soon as I want to record it starts playing up, what can I do??
It may be the box is on the way out, but can you try YouView Maintenance Reset
Hope it works but if not then please let us know and I’ll flag for further assistance from the OCE's.
DandD
Hello, thanks for the advice, I have done a factory reset, but I still can't pause or rewind live tv & now the playback isn't working. Tried to record & it only records part of the programme & then I can't change channel!
Ok I'll escalate for you
fre55die
Hi @DandD
To speed things up IMPORTANT !!!!!!
Hi DandD
I'll swap out the box and we can then retest.
DandD
Thank you, look forward to hearing from you!
No Problem 🙂
The replacement box is on the way.
DandD
My new box arrived really quickly, all changed over & working perfectly, on my way to the post office today to send the old one back, thanks for your help in sorting this out without any drama!!
Glad the new box has arrived and is working ok for you.
