Youview problem
5 REPLIES 5
clive2e
Hi my names Clive and I have been with talktalk for several years with few problems. But the last couple of days when trying to catch up with ITV hub it requires signin. How is this done?
Just click OK to Sign In and then follow the onscreen instructions.
https://help.itv.com/hc/en-us/articles/360005101514-How-do-I-sign-in-on-my-TV-using-PIN-pairing-
Hi Clive
Welcome to the Community.
If you follow the advice from ferguson I'm sure that will help.
clive2e
Thanks everyone . Not clear that you had to register for ITV hub online first and then quote the code shown on your youview box when you tried to sign in there.
Now sorted.
fre55die
Hi @clive2e
You will also probably find that you will need to do the same for BBC, UKTV, All 4 and My 5.
Well I did anyway !!
Hi clive2e
As fre55die advise, most of the broadcasters are going down this route and making people register for access.  This is external to youview and beyond our control.
