Connecting an Android smart phone to the system
1 REPLY 1
Iainschofield
I got a second hand smartphone in Thailand from a reliable source but it won't connect to the router here in the UK. The advice page doesn't cover this brand (Honor) and I can't see a way to progress.
If it is more or less standard Android there shouldn't really be a problem.
When your phone scans for wi-fi signals does it see your router ? Does it see any signals ?
Do you know what encryption standard the phone uses ?
