Access to Port 445 blocked
ettasimone
Message 33 of 33
I'm working from home and my work IT have said that I need access to Port 445 in order to access the work drives and that this has been blocked by my internet service provider. Can someone help
Lore
32 REPLIES 32
Message 1 of 33
Hi Loretta
I'm so glad to hear this, thanks for letting us know 🙂
Message 2 of 33
Hi, I have just tested and it worked, I can access the Drive I need to access. Thank you for your help.
Lore
Message 3 of 33
We've made an additional change to the firmware. Please can you try retesting the VPN again and letting us know how you get on.
Message 4 of 33
Hi Loretta
Sorry for the delay. I'm still waiting on additional information from our Devices Team.
Message 5 of 33
Hi Loretta
I'm just checking with our Devices Team to see if there is anything else we can try.
I will post back shortly.
Message 6 of 33
Hi @ettasimone
Did you ask your employer which VPN client (the software you use on your PC to connect to your work's network) they have installed on your PC? If I know which one it is, I might be able to test it on my PC (I don't want any details about your work).  I will try to test it on a public server somewhere.
Message 7 of 33
Hi, I have just checked this morning and it is already set to medium.
Lore
Message 8 of 33
HI Loretta
Did you try the different firewall settings?
Message 9 of 33
HI Loretta
If you log into the router admin page using the router admin password from the back of the router.
Under internet settings / advanced settings / access control.
Dashboard - see Wi-Fi settings - manage advanced settings - access control - firewall.
Message 10 of 33
Thanks, how do I change my router settings?
Lore
Message 11 of 33
HI Loretta
Your IT department will install software (vpn client) on your laptop.
We don't block VPN but we did have an issue with the previous firmware and certain VPN clients. This has since been resolved with the latest update to your router firmware.
One last thing I can suggest is to check the firewall level in your router settings. If this is set to high then please can you try changing this to medium?
Message 12 of 33
Hi, can you explain what you mean by VPN client. I don't know what that means. I am using a VPN.
Lore
Message 13 of 33
Hi, I did respond when you asked this, I said I am using a VPN, and I don't know what you mean by client. I don't work in IT so that doesn't mean anything to me.
Lore
Message 14 of 33
Hi @ettasimone
Please can you confirm which VPN client you are using?
Message 15 of 33
Hi @Debbie-TalkTalk I did ask exactly this back in post #14, but I have had no response from @ettasimone on this.
Message 16 of 33
We don't block ports. Are you using a VPN client on the laptop?
Message 17 of 33
Hi, I am working on a company laptop at home.
Lore
Message 18 of 33
Hi, I powered down my router this morning for 30 minutes, IT still say I don't have access to Port 445. This is what they have said:
Unfortunately the port still hasn't been opened for you. At this point I'd provide this screen shot and explain the work that they've carried out hasn't worked. Additionally, if you ask them to provide proof to us that they have opened it, this should give us a good idea as to whether they have tried to open the port.
Loretta
Lore
Message 19 of 33
Message 20 of 33
Hi @ettasimone
Just to confirm, we have been working on the assumption that you are trying to access resources at work via TCP port 445 and not something on a PC at home from work. Is this correct? The direction of the connection to port 445 is crucial to understand your problem & rectify it.
