Broadband keeps disconnecting every minute
anita7
Chat Champion
Message 22 of 22
Since yesterday afternoon my broadband keeps disconnecting every minute.
The line test says it works fine but in reality it doesn't.
I have already tried restart, test socket etc. without any luck.
Any ideas?
21 REPLIES 21
Message 1 of 22
I'll order the router, it should be with you within a couple of working days
anita7
Chat Champion
Message 2 of 22
Ok
Message 3 of 22
We can send one to test with, would you like me to arrange this?
anita7
Chat Champion
Message 4 of 22
I don't have a second router. The engineer threw away the old one because he said it's too old and I should not use it.
Message 5 of 22
OK thanks. Have you tested with a second router?
anita7
Chat Champion
Message 6 of 22
Yes
Message 7 of 22
Hi anita7,
So just to confirm, you currently have the router and one telephone connected to the test socket via a micro-filter?
anita7
Chat Champion
Message 8 of 22
No noise on the telephone line, router connected to the test socket at the moment.
Message 9 of 22
I'm sorry to hear this and I will take a look now. I've run a test on the line which hasn't detected a fault, however I can see that SNR is varying quite a bit. Is there any noise on the voice service? Is the router still connected to the test socket at the moment?
anita7
Chat Champion
Message 10 of 22
Hi Chris,
The broadband is not working again since last night. The telephone works fine. Can you please investigate? It's becoming unacceptable to have so many issues in such a short period of time.
Message 11 of 22
I'm sorry to hear this. Would you like us to send a replacement router for testing purposes to see how the connection compares and to rule this out?
anita7
Chat Champion
Message 12 of 22
I have issues again with the broadband, it is terribly slow, the normal speed is 7.5/0.9 Mbs but at the moment I have0.9/0.8 Mbs.
Any idea what's going on with my connection?
Message 13 of 22
Hi anita7
If you do experience any further issues then please let us know and we can send a router for testing.
anita7
Chat Champion
Message 14 of 22
The connection has been stable since my last post so I assume it has been fixed.
I'll let you know if it starts acting again.
Thank you for your help!
Message 15 of 22
OK thanks. Do you have access to another router that you can test with?
anita7
Chat Champion
Message 16 of 22
The socket is 5C MK4 and the router is currently connected to the test socket with a filter but it makes no difference.
Message 17 of 22
OK thanks. Does you master socket have a master socket, if it does could you try connection your router to it and let us know if there's any improvement (line test is passing)
anita7
Chat Champion
Message 18 of 22
Only one socket by the front door where only the router is connected.
I don't normally have a telephone connected but I have one now for testing purposes.
Message 19 of 22
OK thanks, how many telephone sockets do you have? Do you have anything connected to your telephone socket(s) in addition to your router and one telephone socket?
anita7
Chat Champion
Message 20 of 22
 Hi Chris,
The telephone line is clear and it works as normal. No noises or crackling.
