Changing NAT Type
threefins
Message 7 of 7
Dear Community
I need to change my NAT Type to open to optimise my online gaming experience. It’s presently set to Moderate, I assume by default. I have a Safecom FAST5364 router. Would be grateful for help in achieving this.
Cheers
Darren
6 REPLIES 6
Message 1 of 7
Hi threefins
I'm so glad to hear this, thanks for letting me know 🙂
Message 2 of 7
Hi Debbie
Thank you for your suggestion wrt resetting the router, that solved it. NAT Type now displays OPEN.
D😊
Message 3 of 7
Thanks @DanMay94 @for helping out. Yep, Series X too but hardwired with an Ethernet. @Debbie-TalkTalk has asked me to power down the router for 30 mins to reset it, hopefully that will sort it🤞🏽
D😊
Message 4 of 7
Thanks Debbie, I’ll try that.
D😊
DanMay94
Message 5 of 7
Hi Darren,
I recently opened a thread a few days ago as I am having the exact same issue with my Xbox Series X. After having played with it for a few days I got really stuck. Last night I tried hard wiring by Ethernet and so far I have had an open nat for a day, can you try hardwiring at all?
Message 6 of 7
Hi Darren
Can you try powering down the router for 30 minutes to reset the router.
What specific issues are you experiencing when gaming?
