Connection speed has slowed down
jcnporter
Message 7 of 7
When I log into my router, the internet speed to the router is showing 67Mbps, however when I do a speed test on any of my devices, I cannot get more than 30Mbps, even with a wired connection and only one device active.
I was getting 50+ Mbps only a few weeks ago.
6 REPLIES 6
Message 1 of 7
That's great news, thanks for letting us know.
Message 2 of 7
It seems this has solved the problem, speeds are now 58mbps again. Thanks for you help!
Message 3 of 7
Thanks for confirming. I've run a test on the line now which is clear and the sync speed looks consistent. Could you try powering down the router for a full 30 minutes please and then try another speed test as this will reset the current session and can often increase the throughput speeds?
Message 4 of 7
Hi Michelle,
It seems to be a permanent drop, I've rebooted the router a number of times and the speed is consistently 28-30Mbps.
When I log in to the router dashboard, it says that the internet connecction is 67mbps as below, so it looks like an issue with the router?
Router dashboardRouter dashboard
Message 5 of 7
Can I just confirm, is this permanent or intermittent? Does the speed improve if you reboot the router?
nophead
Whizz Kid
Message 6 of 7
Does it get worse in the evenings when people are at home?
