Glacial speeds
JoycePercival
Message 13 of 13
The speed to my router is 52 Mbs which I suppose is ok but the speed to my device is 8Mbs.  I need technical help with the router but I have no idea how to contact Talk Talk.  Does anyone know how to get help?
JP
12 REPLIES 12
Message 1 of 13
Hi JoycePercival
Sorry for the delay.
Let us know how the connection/speed compares with this router.
Gliwmaeden2
Message 2 of 13
I'll re-escalate this thread for you, @JoycePercival.
Staff will be back after the weekend.
Message 3 of 13
Yes please Chris.  My broadband is next to useless at the moment.
JP
Message 4 of 13
Thanks. Line test isn't picking up any issues. Would you like me to send another router to test with?
Message 5 of 13
Thanks Chris.  Profile completed
J
JP
Message 6 of 13
Hi Joyce,
I've enabled PM's. Could you update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 7 of 13
Many thanks.
JP
Message 8 of 13
I will ask TalkTalk to enable your PM's so as I can send you this information. I will also ask them to first consider replacing your router as it is quite old now. Once you get it let me know how it is & I will help you further then.
Message 9 of 13
Thanks Keith,
It's a Huawei HG633.  It's set to operate on both bands.
JP
Message 10 of 13
Hi @JoycePercival
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 11 of 13
It's wifi connected and within 2m and line of sight of the router
JP
Message 12 of 13
Is this a Wi-Fi connected device or a wired (Ethernet) one?
I will move this thread to a more appropriate area within the forum.
