Must I use the eero Pro 6 Mesh system on TalkTalk full Fibre?
wildbill
Message 4 of 4
I have just purchased a Fibre 900 connection from TalkTalk.
I have been with TalkTalk for many years and today ordered the Full Fibre 900 product as an upgrade from TalkTalk Fibre 35.
The Fibre 900 will be installed early June 2023.
I currently have and use the TalkTalk WiFi Hub (black version). My 3 PC's are LAN connected and we only use WiFi for phones that only support WiFi 5, and a SMART TV.
So my questions are.
Do I have to use the eeroPro 6?
Or can I just use the TalkTalk WiFi Hub with the Fibre modem (ONT) connected to the WAN port on the WiFi hub?
3 REPLIES 3
Message 1 of 4
Thanks for your post and please let us know if you need any assistance 🙂
wildbill
Message 2 of 4
I realised my bad grammar after posting the message but  couldn't find the edit button to correct it.
Found it now so I will correct it.
And thanks for the answer.
I think I may leave the eero's in the box and keep them for future use when we get some WiFi 6 enabled devices.
Message 3 of 4
You have actually asked two questions at the end there!
And the answers are: No; and Yes.  🙂
