Slow download speed
GardenMike
Message 31 of 31
Hi - can you help please.
Almost every day I get download speeds of less than 1Mbps via wifi and wired connection until I restart the router, then I immediately get around 20 Mbps.
The Service Centre reports router speeds of 30Mbps on the daily checks.
Can someone advise what to do.
Mike
30 REPLIES 30
Message 1 of 31
I've re-run the line test now which is clear and the connection looks stable. How have you found the overall performance of the connection? If the connection is ok at the test socket then this could suggest a potential issue with the faceplate or any internal wiring connected to the line.
Message 2 of 31
Hi @Debbie-TalkTalk - the line stability seems good still.  Can you run a line test and check the connection stats to confirm that you think it is good too.    I still have the filter plugged into the test socket, does this mean that I need to replace the master socket ?
Thanks for your help
Mike
Message 3 of 31
I'm glad to hear this and thanks for the update. I've re-checked the connection stats now and the sync speed and the stability both look very consistent for the last 5 days.
Thanks 🙂
Message 4 of 31
Hi @Debbie-TalkTalk , the line has been stable since the filter was plugged in and speed has been consistent.  A line test and check of the connection stats would be great.
Mike
Message 5 of 31
Hi Mike
How are you getting on? Would you like me to run a line test and check the connection stats?
Message 6 of 31
Hi Mike
Ok no problem. I will check in again with you before Friday.
Thanks again.
Message 7 of 31
Thanks for checking in - I haven’t been using it as actively today as previous days.  I will know more in about 24 hours, but so far there have been no problems.
Mike
Message 8 of 31
Hi GardenMike
How's the connection been since yesterday? (with router at the test socket)
Message 9 of 31
Hi GardenMike
Thank you. I will check in with you again on Wednesday afternoon to see how the connection has been.
Message 10 of 31
Hi @Debbie-TalkTalk
Yes, no problem - it doesn't seem to affect the internet or phone.
Message 11 of 31
Hi GardenMike
Thanks for your reply. Yes that is the test socket.
Would it be ok to leave the router and filter at the test socket for at least 48hrs?
Message 12 of 31
GardenMike
Message 13 of 31
It looks like NTE 5C MK 4 is the right one
Message 15 of 31
Hi @Michelle-TalkTalk  - I have opened the master socket and it doesn't have a test port.  But I have added the microfilter to it while the cover is removed - will this have the same effect ?
Message 16 of 31
Thanks for confirming. Would it be possible to connect the microfilter, router and phone at the test socket so we can see how the connection stats compares please? Does the speed always drop at the same time?
Message 17 of 31
Hi @Michelle-TalkTalk , I have a Openreach Master Socket 5C which I *think* has a test socket.
When the line speed drops to <1Mb I check it also by checking the device that is wired by ethernet to the router to make sure that it isn't wifi that is causing the slow speed.  Then just power cycling the router brings the speed back to around 20Mb straight away.
Are there any other troubleshooting steps that you'd like me to do when the speed drops ?
Mike
Message 18 of 31
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault, however I can see that the sync speed has dropped. Does your main socket have a test socket please?
GardenMike
Message 19 of 31
Hi @Chris-TalkTalk and @Debbie-TalkTalk
The connection has just dropped to <1Mb again now.  What could be the next troubleshooting steps ?
Message 20 of 31
