Slow download speed
GardenMike
Message 31 of 31
Hi - can you help please.
Almost every day I get download speeds of less than 1Mbps via wifi and wired connection until I restart the router, then I immediately get around 20 Mbps.
The Service Centre reports router speeds of 30Mbps on the daily checks.
Can someone advise what to do.
Mike
30 REPLIES 30
GardenMike
Message 21 of 31
Hi @Debbie-TalkTalk and @Chris-TalkTalk - I have swapped out the router and had the same problems again where speed was fine in the morning and then dropped to 0.7Mb in the late afternoon based on 'speed test' .
I've reset it now and will let you know if it happens again.
Mike
Message 22 of 31
GardenMike
Message 23 of 31
Hi @Debbie-TalkTalk  - the delivery of the new router was super quick, thank you.  I have been away for a bit of Christmas and know that I need to reset the wifi name when I plug it so I haven't done that yet.
Thanks for checking in
Mike
Message 24 of 31
Hi Mike
How are you getting on, have you received the replacement router?
Message 25 of 31
Message 26 of 31
Thank you @Debbie-TalkTalk , I will report back on this thread.
Mike
Message 27 of 31
Hi Mike
No problem 🙂
The router is on its way, please allow 48hrs for this to arrive.
Let us know how the connection/speed compares with this router.
GardenMike
Message 28 of 31
Thanks @Debbie-TalkTalk , that would be great if that is the best thing to do.
Many thanks for your quick reply
Mike
Message 29 of 31
Hi Mike
I think we should send a replacement router for testing so we can rule this out. Are you happy for me to arrange this?
Skynet_TX
Message 30 of 31
Hi @GardenMike,
What make / model of router do you have ?
The support team here on the community will be able to help when they return tomorrow, if they did suspect a fault with the router they would be able to arrange a replacement for you, however there may be some other checks they can do first to see if there might be some other cause.
