Sonos issue
Pjay1
Message 19 of 19
I have 2 Sonos speakers that keep disappearing from the app been told by customer service that I need to split the bands and connect them to 2 .4 ghz is this possible and what effect will it have on all other devices I have a sagecom fast 5364 thanks
18 REPLIES 18
Message 1 of 19
Hi Alex,
As advised, please can you create your own topic and we'd be happy to look into this for you.
Message 2 of 19
Hi @alexpearce
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
Message 3 of 19
Hi there,
I have the same setup, are you able to turn this setting off for me too?
Number: REMOVED
Thanks,
Alex
Message 4 of 19
Hi Pjay1
That's great news, I'm so glad to hear this 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Message 5 of 19
Hi @Pjay1
That is great, I hope it lasts. If you do need my help, just post back on here.
Message 6 of 19
Hi Debbie I’ve just been waiting a few days to see if the speakers disappear from the app at all since you turned off the optimisation and so far it’s all working great! When I look in the settings of the Sonos app I can see all the speakers are connecting to channel 1 on 2.4 ghz every time so far which I believe is what they should be doing. A BIG THANKYOU to you and Keith especially for replying so quick.I’ve had this problem for months and didn’t think it would get sorted if it does go wrong I will get in touch for the extra help Keith was offering if that’s ok cheers pjay1
Message 8 of 19
Hi @Debbie-TalkTalk
I am waiting to see if @Pjay1 wants to proceed with my offer of help. He did say that he wanted to see how it performs first, now that you had disabled WiFi optimisation
Message 9 of 19
Hi Pjay1
How are you getting on, how's the connection been?
Message 10 of 19
Message 11 of 19
Thanks for turning it off it will take a few days to see if Sonos stays connected fingers crossed I’ll let you know cheers pjay1
Message 12 of 19
Hi Pjay1
Thank you 🙂
The WIFI optimisation has now been switched off, please let us know how the connection compares.
Message 13 of 19
Hi debbie I have added my name and number I think cheers pjay1
Message 14 of 19
Hi Pjay1
Please can you add your name and TalkTalk landline number to your Community Profile, I can then switch the WIFI optimisation off.
Pjay1
Message 15 of 19
Great thanks I’ll wait to hear👍
Message 16 of 19
No problem, however, there is no point in doing anything until after WiFi Optimisation has been disabled, then I'll send you the guide. I'll make sure that TalkTalk know about this for their return tomorrow.
Pjay1
Message 17 of 19
Thanks for replying I have 2era 100 Sonos speakers that keep disappearing from the app I also have a beam sound bar and another 2 era 100 set as surrounds and they work fine the router is in the same room as the sound bar and surrounds the 2 that disappear are in the next room. I would like talk talk to disable wi fi optimisation . If that happens Keith could you send me the guide for diagnosing problems so we can make some changes and hopefully sort this annoying problem cheers Pete.
Message 18 of 19
I have had experience with these speakers before, which model do you have? The problem is normally caused by WiFi interference, unlike what you have been told.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
