Unable to connect to plex Sagemcom 5364
ocean4127
Message 15 of 15
Recently I have been unable to directly access plex remotely to allow streaming. Nothing has changed in the setup which previously worked perfectly, the relevant ports are forwarded but still I cannot directly connect to the plex server from outside the network.
I think this is a router firmware issue, the router is a Sagemcom fast 5364 firmware
SG4K100136
I can see others have had similar problems but I cannot see a solution being posted. Is there one?
14 REPLIES 14
Message 1 of 15
Hi ocean4127
I'm still unable to connect to your router, is the router switched on at the moment?
Message 2 of 15
Hi ocean4127
I'm attempting to update the firmware. Can I just check that the router hasn't been rebooted?
Message 3 of 15
Yes that will be fine thanks
Message 4 of 15
Hi ocean4127
I will start it around 4pm this afternoon, will this be ok?
Message 5 of 15
If you could wait until after 3pm that would be great, the connection is currently being used for a work meeting! thank you
Message 6 of 15
Hi ocean4127
Thank you. I will need to make a change to your router firmware, will it be ok if I do this now?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Message 7 of 15
Sorry for the slow reply, I've put the serial number in the private notes. Thank you
Message 8 of 15
OK thanks. Could you add the router serial number to the private notes section of your community profile and I'll try to find it on our systems
ocean4127
Message 9 of 15
OK I've done that.
Message 10 of 15
Hi ocean4127
Could you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
ocean4127
Message 11 of 15
Yes that is fine thanks
Message 12 of 15
Ok thanks for confirming. We can try a different version of firmware. Are we ok to update this today? It will take around 20 minutes to complete and the router can't be switched off or rebooted during the update.
ocean4127
Message 13 of 15
Hi, thanks for your help.
The error from plex is that the app is unable to connect securely to the server.
I have tried turning off the router for half an hour as you suggested, unfortunately it did not work. So far I have performed a factory reset on the router, manually port forwarded the relevant ports, I have also re-installed plex with default settings but with no success.
Plex is set to allow secure connections and when accessed from within the network functions normally and its setting state it is accessible remotely.
The set up was working up until recently, given nothing has changed with the network or my settings and it functions normally within the home network I suspect there is a router based issue. Do you have any other suggestions?
Message 14 of 15
Do you see a specific error message when this happens? Have you tried powering down the router for a full 30 minutes and then re-tested this again as this will reset the current session?
