Unable to connect Yale home alarm to eero
Allen07
Message 8 of 8
We are trying to connect our Yale home alarm hub to eero but it will not connect. Tried turning internet off and back on but nothing seems to work.
7 REPLIES 7
Message 1 of 8
Hi Allen07,
That's great news, thanks for letting us know 🙂
Message 2 of 8
Big Thankyou to Talk Talk customer services. Given great advice and sent a different router which has several Ethernet ports. Yale alarm now working.
Message 3 of 8
How are you getting on?
Message 4 of 8
The first thing to do with an Eero is check that legacy mode is enabled. To enable legacy mode, in the app, go to:-
  1. Tap Settings on the bottom right of your screen
  2. Now select Troubleshooting
  3. Tap My device won't connect
  4. Then choose My device can't detect Wi-Fi 6
  5. Toggle Legacy Mode on
How is the alarm supposed to connect to your Eero, by manually detecting the network name & entering the password, WPS or via an app? Do you get any error messages when you try to connect to the alarm.
Message 5 of 8
Hi Allen07,
Do you get any sort of error message when you try to connect the alarm hub?
Allen07
Message 6 of 8
On the Yale website it says it is compatible with 2.4Ghz
Message 7 of 8
Do you know if the Yale alarm uses the 2.4Ghz Band or 5Ghz band.
