VPN Issues
Binx_y
Message 17 of 17
As with a few people, I'm having issues with my VPN that has stopped working.
Solved: VPN issue - TalkTalk Help & Support
Solved: VPN connection issue - TalkTalk Help & Support
Can you please run the update on my router to fix this.
TalkTalk Wi-Fi Hub
router: SG4K100136
16 REPLIES 16
Message 1 of 17
Hi Binx_y
Your router has the correct firmware that should resolve the VPN issue.
I have also completed a line test which is clear. Would you like me to send a replacement router for testing?
Message 2 of 17
Hi @Debbie-TalkTalk  apologies I should've been clearer.
pre-update in July to the firmware: wifi was stable however in May my vpn had suddenly stopped working.
post-update in July to the firmware: wifi is slower, connection is unstable (orange light flashing on router), vpn has still not connected.
Message 3 of 17
Hi Binx_y
Apologies for this.
Just to confirm, is this only affecting the VPN connection?
Skynet_TX
Message 4 of 17
Hi @Binx_y,
The support team here on the community probably won't be around until Monday now. When you have been losing connection what has the LED been doing on the router, does it remain solid white, or does it do something else ?
Binx_y
Message 5 of 17
Hi @Chris-TalkTalk , the update has unfortunately not resolved the issue.
Since the update my connection has been much slower and I've have been losing connection.  Can you please take a look?
thank you for your help so far.
Message 6 of 17
OK thanks for letting me know. Please let us know how you get on
Binx_y
Message 7 of 17
Hi @Chris-TalkTalk  it doesn't see to have resolved the issue when I log on. I'm going to ask our IT support to run some tests now that the firmware has been updated.
Thanks,
Message 8 of 17
Hi Binx_y,
It looks as though the firmware update has completed now, is everything OK at your end?
Message 9 of 17
Great, thanks, I'll update your firmware now, it should complete within 15 minutes, please don't switch off your router
Message 10 of 17
@Chris-TalkTalk
5543
Message 11 of 17
Hi Binx,
Apologies for the delay, could you just confirm the last 4 digits of the router serial number and I'll run the update for you
Binx_y
Message 12 of 17
@Chris-TalkTalk  yes please, can you please run the update.
thanks
Message 13 of 17
Hi Binx_y,
Do you want me to update your firmware now?
Binx_y
Message 14 of 17
Hi @Skynet_TX
It's built in Windows 10
Chris-TalkTalk
Message 15 of 17
Hi Blinx_y,
Would you like me to run he firmware update now, it can take up to 15 minutes to complete?
Skynet_TX
Message 16 of 17
Hi @Binx_y,
When the support team here are back tomorrow they should be able to update your firmware version to one that has better compatibility for VPN connectivity.
What VPN software do you use, or is it the built in Windows 10/11 VPN ?
