VPN connection issue
Zibby1
Message 7 of 7
I have been unable to connect to my work VPN using the built-in Windows 11 VPN. I have verified that I can connect to my work VPN when I try it via O2 or any other WiFi. It's only the TalkTalk connection I have at home which does not successfully connect. I see multiple forum posts regarding the same issue, IT department said is a problem with TALKTALK firmware/router however after replace router to old one which correctly supported VPA last year, still doesn't work correctly.
Could someone please help me with this issue as is massive important?
I have updated my community profile with my details (please contact me on the alternate phone number provided).
Router details --
TalkTalk Wi-Fi Hub
SAGEMCOM Ver FAST 5464-2.T4
6 REPLIES 6
Message 1 of 7
Hi Zibby1
I'm so glad to hear this, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Zibby1
Message 2 of 7
Thank you @Debbie-TalkTalk! VPN connected🙂
Message 3 of 7
Hi Zibby1
Thank you. I will need to make a change to your router firmware. I will post back to confirm once this has been completed.
Zibby1
Message 4 of 7
Hi @Debbie-TalkTalk,
Is am sorry, I have updated my contact details.
Thank you in advance
Message 5 of 7
Hi Zibby1
Please can you add your TalkTalk landline number to your Community Profile, I can then take a look at this for you.
Skynet_TX
Message 6 of 7
Hi @Zibby1,
This may be being caused by the version of firmware running on your router, if so, the support team here may be able to change it to a different version of firmware when they are back tomorrow.
