Wi fi password
Gusg227
Visitor
Message 3 of 3
How do I recover WiFi password
Message 1 of 3
How are you getting on?
Message 2 of 3
It should be on the router somewhere, if it is a recent one check the slot-in tab on the back. If you have subsequently changed and forgotten it then do a pinhole reset on the router, although this will also reset any other other custom settings you may have made.
