Can't access work VPN
PointlessAccount
Message 13 of 13
I am not able to access VPNs through Windows when using my home TalkTalk wifi. It works fine using my office wifi so it must be TalkTalk blocking them in some way. Could this be rectified at the earliest opportunity please as I need to access VPNs to do my job.
12 REPLIES 12
Message 1 of 13
That's great news, thanks for letting me know 🙂
PointlessAccount
Message 2 of 13
Hi Chris,
I've just checked and it appears to be working now. Many thanks for your help.
Message 3 of 13
OK. I'll start the update now. It can take up to 10 minutes to complete, please don't switch off your router
PointlessAccount
Message 4 of 13
Yes please. I am ready now if you are.
Message 5 of 13
OK thanks. We can update your router's firmware to the latest version. Would you like to give this a try?
Message 6 of 13
Actually no, there is an error message. it reads as follows: "The remote connection was not made because the attempted VPN tunnels failed. The VPN server might be unreachable. If this connection is attempting to use an L2TP/IPsec tunnel, the security parameters required for IPsec negotiation might not be configured properly."
PointlessAccount
Message 7 of 13
No, it just says connecting and keeps spinning forever. On my office wifi it connects within 30 seconds.
Message 8 of 13
OK thanks. What happens when you try to connect to the VPN, do you get an error message?
PointlessAccount
Message 9 of 13
SAGEMCOM and the version number is FAST 5364-3. T8
Message 10 of 13
OK thanks. What is the make and model of your router?
PointlessAccount
Message 11 of 13
No, this has been the case ever since I started working from home several months ago.
Chris-TalkTalk
Message 12 of 13
Hi PointlessAccount,
Have you only recently started having problems accessing the VPN?
