Low download speeds, high latency, 10 second dropouts
bradleytt
Message 2 of 2
Hi there - please can you assist me?
I have been experiencing high latency (and 12ms~ of jitter), some packet loss (1-2%), low download speeds (12Mb/s~) (upload is as expected) and regular dropouts/disconnects of about 5-10 seconds each.
The low speeds/high latency are new, the dropouts have been going on for many months.
I have tried the following :
  • Plugged directly into test socket
  • Using TT router rather than my own
  • Replaced cable from router to test socket
  • Replaced filter at test socket
  • Disconnected all devices apart from my PC
It happens on both wired and wireless, it feels like there is congestion/contention. I have set up a Think Broadband BQM to provide a picture to see if it happens only at peak times, I will share once it has been running for a while.
Please could someone take a look?
Many Thanks,
Bradley
1 REPLY 1
Message 1 of 2
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault. Would it be possible to run a few more wired speed tests at different times of the day using the TalkTalk Speed Tester so we can see how the speeds compare please?
