on 26-03-2024 10:32 PM
Ever since I had my new Fibre router (Sage MCOMM) I set the 2.4ghz channel to 6 as the neighbours use 11 - but it keeps changing back to 11.
And on the 5ghz I set it to 60 as the neighbours use 36, but yet again it keeps changing back to 36.
I did this on my last router and you were able to rectify it for me and I would appreciate you doing the same thing again on my new router.
Also the internet speed some nights is dire dropping down to 35mbps - not much use when son is trying to play siege on the PS4
Can you help make it more stable ? and what is my minimum speed?
yesterday
Channel selection is steady but the Wi Fi coverage is woeful.
Have set the 2.4 wifi channel to 6 which is different from the neighbours and the 5ghz channel to 64.
Cant get the 2.4ghz in the next room or upstairs. used to before. Thinking of getting a spare router for upstairs and putting it in bridge mode or consider installing a ceiling mounted access point directly form the internet switch.
Can the wifi power level from the router be turned up ?
on 28-03-2024 08:11 AM
on 27-03-2024 06:53 AM
Hi steven25
I've switched the WIFI optimisation off. It would also be worth powering down the router for a full 30 minutes and then running a speed test to see if the speed has increased.
on 26-03-2024 11:12 PM
Your minimum speed shows on the graph in My Connection (blue button in Service Status Dashboard) when you take a look at the speeds for the past week, @steven25.
Staff will switch off WiFi optimisation for you, when they pick up your post, during the day.
You'll need to ask this to be done whenever you do a factory reset of the router or when it gets a firmware upgrade.
