Effect of Full Fibre Router on Ring Doorbell
allenetc
Message 4 of 4
I have progressed, if that is the right word, from an older TalkTalk router to a newer Full Fibre model. The Ring doorbell, on WiFi update,  now says it can't accept a VPN which I don't have.
What security settings need to be changed, presumably in the router,  to accommodate something that has worked for years?
3 REPLIES 3
Message 1 of 4
Are you using your router's correct WiFi password (not the router one)?
Please can you log into the router & go to:-
Dashboard > See internet settings > Manage advanced settings > TalkTalk Wi-Fi Hub > Maintenance > Logs
Then please PM the logs to me (to protect your privacy) for the time period that covers the last time you tried to connect the doorbell?
Message 2 of 4
Keith,
Thank you for your input so far. The router is a SageComm device and the ring doorbell does not list the WiFi as a network although the phone recognises and uses it far beyond the range of the doorbell. I have to put the WiFi netowrk name in manually and still it doesn't work.
Message 3 of 4
There should be nothing that needs to change, providing that your Ring Door bell connects OK to the new router (which make/model is the router anyway). You might need to rename the 2.4GHz band to separate it from the 5GHz one,
