Upgrade from Fibre65 to Full Fibre 150
Pclimie1
Sightseer
Message 13 of 13
My fibre 65 works fine with my Talk Talk router.  Upgraded to full fibre 150 and received Eero 6 today. When i try and set up Eero it does not connect to Internet.  Plug in my old router again and all ok
12 REPLIES 12
Message 1 of 13
Hi jocat,
I can see that Keith has answered your question, if you need any further assistance can you please start your own thread and we'll be happy to help
Message 2 of 13
You will need to buy a cheap Gigabit data switch with enough ports on it. Please allow at least one extra port, as that will be required to connect to the Eero itself.
jocat
Newbie
Message 3 of 13
My fibre 150 is being installed on 25thApril . Now after looking at Eero box sent in post I cant see how i connect 5 ethernet cables to it .
Can someone enlighten me ?
Message 4 of 13
That's great. thanks for letting me know 🙂
Message 5 of 13
Chris yes thanks.  Managed to set up quickly there before I left for work and all worked.  Thanks for your help.  Speeds of around 75Mbs at the moment.  Will monitor.
Message 6 of 13
Hi Pclimie1,
How are you getting on, have you had chance to try the eero again?
Message 7 of 13
I've made a changed which should resolve the connection issue. Could you try the eero again in an hour and let us know how you get on
Message 8 of 13
OK, no problem, I'll take a look at this now
Message 9 of 13
Thanks @Chris-TalkTalk @ferguson and @KeithFrench .
Didn't realise my old router would still with full fibre150. But no now the Eero 6 is here I think I will give it a go.
@Chris-TalkTalk do i need to phone TalkTalk to progress the se up?
Chris-TalkTalk
Message 10 of 13
Hi Pclimie1,
As ferguson has said, you can continue to use your old router if it better suits your needs
Message 11 of 13
@Pclimie1
I see you have been pointed in the right direction by @KeithFrench, but frankly if your current router works I would stick with that. The eero is more trouble than it's worth in my personal opinion.
Message 12 of 13
There is certainly a profile change that has to be made to use the Eero. I have asked one of TalkTalk's support to pick your thread up and sort it for you.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please also try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
