How do I edit TalkTalk Hub Apps on the Screen?
LTVosper
Message 2 of 2
My new TalkTalk Hub Home screen shows several preselected apps / streaming services.  I don't need them all.  How can I remove them?
There are other apps I want to use which don't appear on the Home screen.  How can I make them show?
1 REPLY 1
Message 1 of 2
You can't delete set apps other than Spotify.
You also can't reorder fixed ones.
You can get to apps quickly by holding down the home button.
