Hub is forever being unresponsive
babibach
Visitor
Message 2 of 2
It has a mind of its own sometimes it will come on then may decide it doesn't want to change channels before freezing up
1 REPLY 1
Message 1 of 2
Have you tried a factory reset from the settings menu?
This will reinstall any software and apps and hopefully clear any bugs in the system.
You will need to sign into your apps again, but worth giving it a try.
