New TalkTalk TV Box Specs and more info????
RazzOne
Whizz Kid
Message 2 of 2
Hi Guys
Where can I find out what the full specs are of the new TV Box?
I would like to know:
1) Can it be recorded on if I insert a Pen Drive or Hard Drive? If so how may channels can be recorded at once?
2) What TV System does it use? YouView or Freeview Play?
Cheers
1 REPLY 1
Message 1 of 2
Which box are you talking about? 4k or Hub?
4k can insert a usb and record. Box has one tuner so can only record 1 channel and can't watch another. Freeview Play.
Hub no recording. Android based. YouView.
