on 27-04-2024 11:15 AM
Hi all Have followed the set-up guide. Put the camera and my phone next to the router, but will not set up correctly. camera is on 2.5GHZ Message on Phone about progress comes up with connected but no internet. at that point it looks as my phone is locked onto the camera but is chucked off my router. Tapo fault finding says check router is not WPA3 only. I have checked settings and it is not. Anybody else had this sort of thing. Priviously tried another Smart camera and that did not connect either, So I am thinking it is an issue with the router. all help Greatfully appreciated.
Thursday
Thanks very much for that clarification @SIXBIKES.
Thursday
Hi Keith. Just to clarify. My Phone has the supersafe Boost installed. Has been there for ages.
When I was trying to run the Tapo Cam app, to connect to my WiFi, It would not allow my phone and the Cam to connect to my
Huawei DG 8041W-2.T5 router at the same time. I must have spent a day trying different things.
But it just would not work as it should do.
Then I wondered if it was the supersafe Boost that was trying to protect my phone from data intruders.
So I uninstalled the Supersafe boost of my phone and ran the Tapo cam Install link again, and it worked fine. I had control of my Tapo indoor Cam C200. For safety's sake. I then reinstalled my Supersafe boost, and the cam app still worked as it should.
Hopefully you may be able to steer another user around this problem.
Thursday
Hi @SIXBIKES
I am glad to hear that you got this sorted in the end. Can I just check that it was SuperSafe Boost installed on the phone that also runs the Tapo app that you had to uninstall?
Wednesday
Hi Random Thoughts. Yes I got it sorted. Came to the conclusion that it might be because I am running Talk Talk SuperSafe virus and Hacker protection . So I uninstalled this , and then tried to connect my camera to the router again. Steps went ok this time, and then reinstalled Supersafe.
Wednesday
Hello did you manage to fix this issue. I've got what I think is the same problem with the same tapo camera.
on 29-04-2024 09:31 AM
Hi @SIXBIKES
@Michelle-TalkTalk has asked me to help you with this camera. I assume that it should connect via an app on your phone, rather than WPS or manually connecting to the router via network name (SSID) & password?
Are both WiFi bands sharing the same network name or do they have two different names?
Which make/model of router do you have?
Do you get any error messages when it fails to connect & if so what are they?
on 29-04-2024 06:56 AM
Hi SIXBIKES,
@KeithFrench - Would you be able to offer any advice on this one please?
