PC can only connect as 'Guest'
mike_in_italy
Message 3 of 3
Long preamble I'm afraid.
Recently had new Sagemcom router following connection to TalkTalk full fibre to the house.
Phone, laptop, Roku and Sonos connected to the new network fine.
The other day I needed to use printer which hadn't been used since new router obtained. Lot of faffing about following Canon connection guide which at one point wanted to try the WPS button ....eventually found a cable and all was well.
Noticed that evening, some strange devices appearing intermittently on network e.g. CSM-Biscuit. Seems that it's probably an Amazon device. Guessing that when trying to setup printer, WPS function allowed a neighbour's device (live in terraced house) to try and connect.
On this basis decided to change WIFI password and disable WPS.
Lots more faffing around, phone reconnects with new password, the old PC connects with new password (though this one is normally on ethernet with wifi disabled, Roku connects with new password, but the laptop which I normally use on wifi downstairs (router is upstairs) can't connect, but can connect to guest wifi.
The laptop is a newish Lenovo Thinkpad running Windows 11. It's not loaded-up with loads of stuff, no anti-virus, use Firefox as browser. It can see the house Wifi but fails to connect within about 15 seconds. I've tried forgetting the network and re-adding it. As far as I can see everything is set to correct values.
This is something of new territory for me. Worked in IT before PCs so not entirely clueless but could well have cocked something up.
Thanks for reading thus far,
Message 1 of 3
Glad you managed to get to the bottom of the issue.
mike_in_italy
Message 2 of 3
Got there in the end. Reinstalled the wireless drivers. Grrrrr - waste of most of the day.
