These handy add-ons are designed to provide backup power to your full-fibre broadband service. This means that even if there’s a power cut, you’ll still be able to access the internet and make emergency calls.
Battery backup units maintain power to the Wi-Fi Hub 2 and Fibre connection box during a power cut, this will enables you to maintain a broadband and telephone service. The battery backup unit will last for one hour, depending on the number of devices requiring Wi-Fi/internet connection.
There are two battery backup units provided for use with your Fibre connection, below are the steps needed to connect them to each device.
A corded phone is required to be plugged into your Wi-Fi Hub2 to enable use during a power outage.
Setup should look like this.
The LED is a two-colour indicator: green or red depending on operation status.
Status | Colour | On/Flash |
Power on with battery fully charged | Green | On |
Power on with charging battery | Green | Steady Flash |
iPower in battery and discharging | Green | Quick Flash |
A fault on the iPower | Red | On |
UPS has detected that the battery is not connected, while the utility power is available | Red | Steady Flash |
Problem | Possible Cause | Solutions |
Red LED is ON | Battery Insulator tab Overload or short circuit occured and iPower transferred to fault mode |
RemoveBattery insulator tab Contact TalkTalk |
Battery backup time does not last an hour | Battery near end of life | Contact TalkTalk |
No output and LED indicator is not on | UPS has detected that battery is not connected or battery voltage is too low or battery is defective | Remove the battery insulator tab from battery if not removed. If red LED flashes even after insulator tab removed contact TalkTalk to replace battery |
We have a reduced support team available at the moment, which means the wait times to speak to us may be longer than usual. Why not manage your account or get help with your services online using one of the below options
