Welcome to the TalkTalk TV remote control guide. Depending on when you joined us and which TV box you use, you'll have a different remote. All the remotes have slightly different guides. Please select the remote name that relates to yours and learn how to use it.
Your TV Hub comes with a remote control that works over Bluetooth as well as Infrared. With Bluetooth you don't have to point your remote directly at your TV Hub and it'll also work from a greater distance. You'll have connected your remote during your initial TV Hub setup. However, if you've received a new remote or need to set it up again, follow these simple steps:
When your remote is in pairing mode the Bluetooth broadcasts at a lower power level. Therefore, please make sure your remote is no more than 1-2 meters away from your TalkTalk TV Hub during the initial pairing setup.
Your remote control will not auto-sync with your TV or Soundbar. If you would like to adjust the volume on your TV using the TV Hub remote, you can easily set it up by following the simple steps below.
You'll now be able to switch between TV Volume mode and TV Hub volume mode by:
When you start watching a live TV channel you’ll be able to pause, rewind and fast forward thanks to temporary content stored on your TV Box. We call this delayed TV. Your TV Hub only stores content on the channel you're watching from the point you started watching it. And when you change the channel, the temporary storage on your TV Box is wiped.
The storage limit for the TalkTalk TV Hub is approx. 30-120 minutes. This varies as it depends on the quality of the channel you're watching ranging from 4K down to Standard Definition.
On Demand uses all the features above, without the limitations of the temporarily stored content. That means you can skip, fast-forward, pause and rewind as much as you like. You can also watch programmes more than once, as long as they're available.
Your remote firmware will be checked automatically. If a newer version is available you'll be given the option to update on your TV.
If you're having problems with your remote you can carry out a reset and re-pair to see if that'll resolve any issues.
Press and hold digits 7 and 9 together for a few seconds until the blue light flashes on your remote. A message will appear 'Your remote returns to default infrared mode'.
You can now pair your remote to the TV Hub by pressing and holding the OK and Home buttons together until the blue light flashes on your remote. A Message will then appear on screen 'Connecting to TalkTalk PC408' and after several seconds will display ‘TalkTalk PC408 connected’.
During the remote setup you may find your TV Hub displays an error message. Please use the guides below to help resolve any errors and pair your remote successfully.
Error message |
Description |
"SCAN ERROR" | This issue happens when the TV Hub is not able to find any remote. Try pairing again and ensure the remote is no more than 1-2 meters from the TV Hub. |
"SCAN TIMEOUT" | Unexpected error. Retry and if it doesn't work, reboot the TV Hub and try again. |
"BOND ERROR" | This usually happens if the TV Hub/remote are not able to bond with each other. 1) Check there is only one remote and one TV Hub in the vicinity trying to connect. 2) Remove pairing info in the remote (press and hold digits 7 and 9 together for a few seconds until the blue light flashes on your remote) and try again. 3) Try replacing the batteries in the remote. |
"CONNECTION ERROR" | This error happens when bonding is complete but the TV Hub is unable to setup a connection with the remote. 1) Check there is only one remote and one TV Hub in the vicinity trying to connect. 2) Remove pairing info in the remote (press and hold digits 7 and 9 together for a few seconds until the blue light flashes on your remote) and try again. 3) Try replacing the batteries in the remote. |
HDMI CEC is enabled on your TalkTalk TV 4K box as default. This feature allows you to control your TV and your TV box with only one remote control. To review the HDMI CEC options, please follow these simple steps:
Your TV will also need the HDMI-CEC feature enabled. If your TV doesn't support this feature or it's disabled, you'll normally get a warning message.
You'll now be able to use your new remote to control your TV.
You won’t always see HDMI-CEC listed as a feature in your TV specification or in the menu. Instead, some TV manufacturers use their own name. The following example names all refer to HDMI-CEC, so if your TV has any of these features, it's supported. Please check with your TV manufacturer if it's not listed below.
You can pause live TV and then restart viewing or fast forward / rewind back to the point you paused the programme. However, you cannot immediately rewind live TV to an earlier time.
You can quickly filter your favourite channels while in the TV guide. Simply press the green interactive button on your remote to only view the channels you've chosen as favourites.
Your TalkTalk remote control will automatically sync up with your TalkTalk TV Box, however, will not auto-sync with your television. If you need to adjust the volume on your TV, you can do this by pairing it with your TalkTalk remote.
Before you start, turn the volume of your TalkTalk TV Box up to a high setting using your TalkTalk remote. This will ensure that the sound isn't too quiet after pairing.
You'll now be able to control your TV using your TalkTalk remote.
Digit. Top 10 brands | |
1. Grundig | 6. Samsung |
2. JVC | 7. Sharp |
3. LG | 8. Sony |
4. Panasonic | 9. Thomson |
5. Philips | 0. Toshiba |
If your TV manufacturer isn’t listed, follow our steps below and use the manufacturer codes below to find your 4 digit code. We recommend working from the left (the most popular codes) trying each one until you find the right one.
Keep trying the codes listed next to your TV’s manufacturer, working from the left (these are the most popular) until you find the correct one. You'll need to repeat all the steps above each time you try a new code.
You can search the codes a lot easier for your TV by pressing CTRL + F.
When you start watching a live TV channel you’ll be able to pause, rewind and fast forward thanks to temporary content stored on your TV Box. We call this delayed TV. Your TV Box only stores content on the channel you're watching from the point you started watching it. And when you change the channel, the temporary storage on your TV Box is wiped.
The storage limit varies depending on which Box you have. For the TalkTalk TV Plus Box it's about 2 hours and for the TalkTalk TV Box it's about 30 minutes. Content storage can also vary when it comes to HD.
If you're having problems with your remote or unable to control your TV, you can try resetting your remote and TV Box to resolve the issue.
Press and hold digits 1 and 6 on your TalkTalk remote at the same time for 3 seconds. During this time the red LED will remain off. After 3 seconds the red LED will turn on, then enter 981 on the remote. The red LED will blink to confirm it's reset and you should be able to use it.
If resetting your remote hasn't worked, try resetting your TV box. Press the ON/OFF button on the back of your TV box. Turn the box back on and press + and - buttons on the front of the box at the same time for 15 seconds. This will take your TV box into Maintenance mode. Scroll down to "Factory reset Keep recordings" and press OK. If your remote does not work, you can use the + and - buttons on the box.
The TV box will reboot and you will be taken through the setup wizard.
If you're having any problems with your remote control you should always check or replace the batteries first.
If you continue to have problems after you've completed the steps above, there might be a technical problem with your remote. Please contact us to discuss a replacement remote control.
We have a reduced support team available at the moment, which means the wait times to speak to us may be longer than usual. Why not manage your account or get help with your services online using one of the below options
