Our Wi-Fi Hub is a breeze to get connected — just follow this step by step guide to get your Full Fibre service up and running. If you have an engineer coming they’ll take care of the set up for you, but if not, simply plug it in, switch it on and away you go. There’s also some helpful tips to get the most of your Wi-Fi Hub 2 below.
The way you set up your Wi-Fi Hub depends on which main phone socket you have. Choose yours from the options below.
Connect Wi-Fi Hub2 to black fibre box with Ethernet cable
To use a wired connection, simply plug the Ethernet cable into your device. Then plug the other end into any of the yellow Ethernet ports on the back of your Wi-Fi Hub.
Devices connected with wire to W--Fi Hub
The light on the front of your Wi-Fi Hub will change colour depending on the status of your connection.
Solid White for 30 seconds then Amber flashing for 3 seconds then back to Solid White (& repeat) means SIP registration has failed.
Wi-Fi Protected Setup (WPS) lets you easily connect network equipment like wireless printers to your router. Instead of manually typing in your Wi-Fi password, you simply press the WPS button on your Wi-Fi Hub to connect your device. Here’s how to do it:
If you've contacted us about a concern with your router, one of our team might have asked you to reset it. If you've not done this before, our video below will walk you through the necessary steps.
You might also be asked to turn the router on and off. If that's the case, our video below will walk you through the necessary steps.
Leave your Wi-Fi Hub 2 on all the time. Turning it on and off will slow down your connection and prevent updates.
Keep your Wi-Fi Hub 2 upright, up high on top of a cabinet or shelf, and facing into the room for the best signal.
Keep your Wi-Fi Hub 2 off the floor and clear of obstructions like electronics, furniture or other signal-blocking obstacles
It's really simple: just plug your phone into the Phone port (green port) located on the back of the Wi-Fi Hub 2, and you're good to go. If your phone doesn't begin working immediately, try turning the Wi-Fi Hub2 off and then back on again to reset it.
The phone port may be located under a sticker, you'll just have to peel this off to use.
White fibre connection box
Black fibre connection box
Wi-Fi Hub light guide
Connect using WPS
Resetting your router
We have a reduced support team available at the moment, which means the wait times to speak to us may be longer than usual. Why not manage your account or get help with your services online using one of the below options
