If you're moving your mobile service to another network, you might find that your phone is locked to Vodafone. If you're not sure, you can check by inserting a SIM card from any network other than Vodafone into your phone. If you see an error message such as:
Network Locked
Invalid SIM
PAYT Lock
SIM Card Not Accepted
Enter SP Code
Insert Correct SIM Card
Your phone is locked to Vodafone. You'll need to get your phone unlocked before you can use another network SIM card. The good news is, we can arrange this for you free of charge.
Contact us and ask for your phone to be unlocked
Confirm your phone's IMEI, model name and manufacturer
Your phone will be unlocked so it works on all networks
The IMEI (International Mobile Equipment Identity) is a 15 or 17-digit code, which is unique to your device. You should be able to find it:
You'll need to know the model of iPhone you have before you contact us. We'll need to know whether it's an iPhone X, iPhone 13, iPhone 14 Pro etc. There are a couple of ways you can find the model of your iPhone if you're unsure:
Tap Settings in the main iPhone menu and then and tap on your iCloud profile at the top of the menu. You'll see your model name listed a little way down the page as 'This iPhone XX'.
Connect your iPhone to iTunes on your computer. Once you've selected your iPhone, you'll see your model name at the top of the screen.
Tap Settings from the main menu > About.
Your model name and number will be displayed in the Phone Information Section.
Type in *#0000# on your phone's keypad. The display shows your phone's model.
Once we've let you know that your unlock request has been processed, here's how to unlock your phone:
iPhones are unlocked Over the Air. Simply insert your new SIM card and start using your new service.
If you’re having problems using your Network Unlock Code (NUC), make sure you’re entering it correctly. Network Unlock Codes are case sensitive, so you’ll need to enter it exactly as it was given to you.
The NUC will work for only the specific device you gave us the details for. If you want to unlock a different device that's been used on TalkTalk Mobile, you’ll need to contact us.
You only get a limited number of attempts to type in your code. If you’ve entered it correctly but are still having problems, we recommend you contact us for support and to double check your NUC.
If your mobile phone is locked to another network provider (other than Vodafone), please see the contact details below:
Network | Contact details |
O2 | 0844 809 0222 (pay as you go) or complete the O2 online form |
Orange (EE) | 07973 100 450 (pay as you go) 07973 100 150 (pay monthly contracts) or complete the EE online form |
T-Mobile (EE) | 0845 412 5000 or complete the EE online form |
Virgin | 0845 6000 789 |
Three | 0843 373 4444 (pay as you go) 0843 373 3333 (pay monthly contracts) |
Tesco Mobile | 0845 301 4455 or 4455 from your Tesco Mobile |
Talkmobile | 0333 304 8064 or 5888 from your Talkmobile |
