Wi-Fi Hub light too bright?
Our Wi-Fi Hub is packed with the latest technology to give you our fastest, most reliable Wi-Fi signal ever, so you can enjoy doing what you love online in every corner of your home.
Lots of our customers have been sharing how much they love the Wi-Fi Hub in our Community, and recently we've seen a few of you asking how to turn the light off. So, we've put together the below guide with instructions for turning off the LED on the front of your Wi-Fi Hub.
Wi-Fi Hub Black
  1. Open your browser and type 192.168.1.1 in the address bar to go to the router admin page
  2. Login with your router username and password. You’ll find these on the sticker underneath the removable settings card on back of your Wi-Fi Hub
  3. Select See Internet Settings
  4. Select Manage Advanced Settings
  5. Select the TalkTalk Wi-Fi Hub icon at the top of the page
  6. Select Light Control
  7. Select the ON button to toggle it on or off and then choose Apply
Wi-Fi Hub
  4. Select Manage Advanced Settings and then Continue
  5. Select Advanced Configuration
  6. Select Maintenance Diagnostics
  7. Select Indicator Status Management
  8. Select ON or OFF. You can also schedule when the light will turn on or off
