TalkTalk Fibre 900 PLUS with Total Home Wi-Fi is a brand new service. Partnering with Amazon to bring you the best experience & connectivity throughout your home. A specially-trained engineer will visit your home to install fibre and connect your eero router. The cabling we use for Full Fibre is delicate compared to standard broadband, so it must be handled carefully and tested to make sure everything is perfect.
Download the TalkTalk PLUS app to manage your installation, get the latest updates on your order as well as being able to request a new date for your Full Fibre installation, all from your PLUS app. Don't forget, you'll need to change the appointment before 12 noon the day before your appointment, not including weekends and bank holidays.
An example : let's say your appointment is booked for Monday between 8am & 1pm. You have until 12 noon, on the Friday before to change the appointment. You'll need to contact us, if you need to rearrange your appointment after this time and may incur charges.
Your equipment will be sent around three days before your installation, arriving just in time for your appointment. The engineer will text or call on the day to update you with their arrival time. Before then, you'll need to think about and complete the following tasks;
Don't forget - Your engineer can arrive any time during the time slot you've agreed and your install with take between two & four hours to complete so be sure to plan ahead and give yourself plenty of time.
Your Full Fibre setup can take up to four hours. Here's a brief summary of what to expect on the day of install:
In a small number of cases, additional work may be required. If this is the case the engineer will discuss this with you. If the engineer needs to work at a height they may also need to drill another small hole to secure their ladder and harness. This will be left neat and tidy when the engineer has finished.
Don't sweat it, we've collated the top questions being asked by our other customers about their Fibre 900 installation. Head over to the community to ask a different question or chat to us from the TalkTalk PLUS app.
The time taken to install your Fibre 900 PLUS can vary depending on how much work needs to be complete. However most customers report that their install takes between two and four hours.
When you placed your order, You'll have selected either an AM or PM slot. Our engineers can arrive at any time during this time slot, so be sure to allow enough time. For example, let's say you have an appointment tomorrow morning between 8am and 1pm, this means the engineer may arrive at 1pm and take four hours to complete the installation, meaning they may not be finished until 5pm.
You can change your appointment from the TalkTalk PLUS app. The latest time you can change your appointment is 12pm the day before your appointment, not including weekends and bank holidays.
For example, If your appointment is on a Monday, you can change your appointment up to 12pm on the Friday before. If you change or cancel your appointment after this, the engineer may still arrive and you may be charged for a missed appointment.
We’ve partnered with Amazon eero to bring you the best Wi-Fi experience, combining the latest Wi-Fi 6 tech with an easy-to-use app for connecting and managing your devices safely and securely. The eero Wi-Fi mesh network is super smart and seamless — it keeps your devices connected, around the home, all the time. The eero system starts with one eero device connected to your fibre connection which the engineer will connect. We also supply a second eero node with your Total Home Wi-Fi and your network can be extended with further eero routers. Total Home Wi-Fi takes eero to the next level by guaranteeing great Wi-Fi throughout your home, and by great Wi-Fi we mean at least 10Mbps, which is enough to stream in HD.
The Customer Splice Point (CSP) is a small box fitted to the exterior wall of your home. This is where we connect the fibre cable from either a pole or underground to your property.
Your Fibre 900 PLUS setup can take up to four hours. The engineer will connect your home with a new fibre cable and two small boxes on the inside and outside of your home. They will discuss the best route for the cable that minimises disruption. This may include digging a narrow channel in your garden or driveway. If they do need to dig, they'll leave it as close to how they found it as possible
We'll always leave your property as close to how we found it as possible, including filling any holes and replacing anything we've moved. If you believe the engineer has left your home in an unsatisfactory state, please contact us so that we can investigate any concerns with you.
If your broadband is currently connected to your home by an overhead cable then we won't need to do any digging to install your fibre broadband. If your broadband cable is underground, the engineer will need to dig a narrow channel on your driveway or in your garden to connect your house to our fibre network. The engineer will agree with you the most effective route and will leave your property as close to how we found it.
