Broadband speed
Daryl
Message 48 of 48
hi, can you confirm what broadband speed i should be able to get at my property please.
thanks
47 REPLIES 47
Message 21 of 48
Hi Daryl,
There have been no further speed increase yet, can you bump the thread on Monday and we'll check again
Message 22 of 48
Thank you for the update and we will re-check the connection stats tomorrow morning to give DLM time to monitor and possibly adjust the speed.
Daryl
Message 23 of 48
Hi. The new router is now connected directly to the test socket. Thanks
Message 24 of 48
Hi Daryl
Once the new router arrives, please can you connect this router at the test socket for 48hrs without being rebooted so DLM can monitor the connection/adjust the speed.
Daryl
Message 25 of 48
ok thats fine.  how is on your site and others when i look at current deals and enter postcode/address they are all saying my minimum guarantee download speed is over 30mbps.?
Message 26 of 48
The current sync speed is within the predicted speed range for the line, however we could try the alternative router just to see how this compares and to rule this out. If there is no change then this is likely to be the best speeds for your line.
Daryl
Message 27 of 48
Thats fine, thanks for that.  What speed do you think i should be able to  get then please?
Message 28 of 48
Ok, would you like us to send a replacement router for testing purposes just to rule this out? We would also send a router returns bag so that one of the router can be returned.
Daryl
Message 29 of 48
Hi, i dont have another Router?
Message 30 of 48
I've re-checked again but there has been no further increase. Do you have a different router that you could test with please?
Message 31 of 48
Hi Daryl,
There have been no further changes so far, we'll check again on Monday
Message 32 of 48
Thanks for the update.  I've re-checked and I can see that the sync speed has increased slightly since your last post. We'll re-check this again in 24hrs to see if DLM has made any further changes to the speed.
Daryl
Message 33 of 48
Wiring is now connect to test socket. Pics can be uploaded if you need to see anything.
ill await your findings.
Message 34 of 48
Daryl
Message 35 of 48
thanks i'll confirm later once it has been done.
Message 36 of 48
Hi Daryl,
It would be better to connect the router to the test socket but you could initially just try connecting the extension lead to the test socket if it more convenient, and we'll see if there's any improvement
Daryl
Message 37 of 48
the main test socket is in my loft with a connection running to another socket in the lounge where the router/phone is connected, do i need to plug the router into the test sockets or can i just unplug the lead in the loft and plug into the test socket?
Message 38 of 48
Yes if possible please can you connect the microfilter, router and phone (if you use a home phone) directly at the test socket behind the faceplate. There may be some wires connected behind the faceplate so we'd recommend gently moving the faceplate so not to disturb any internal wiring connected behind.
Daryl
Message 39 of 48
so just to confirm, i need to take the lead from the top of the master socket and put it into the one behind the plate, and leave everything connected as it is.
speeds i would say top speed on a test would be 9mbps at the most.
Message 40 of 48
Ok thank you. We can then re-check the speeds over the next few days. It can take up to 48hrs for DLM to start making changes to the speed if the connection remains stable. Can I just ask, what are the fastest speeds that you've received with us?
