Broadband speed
Daryl
Message 48 of 48
hi, can you confirm what broadband speed i should be able to get at my property please.
thanks
47 REPLIES 47
Message 1 of 48
Daryl
Message 2 of 48
will do. thanks
Message 3 of 48
Hi Daryl
Please can you keep the new router and return the old router using the pre paid returns bag.
Daryl
Message 4 of 48
Can you confirm if i need to send the new router back or the old one please.
Message 5 of 48
Hi Daryl,
I can see that Gliwmaeden2 has answered your questions, please let us know if you need any further assistance
Message 6 of 48
You need to do some homework on this, @Daryl.
There is a FTTP Fibre65 as well as a FTTC Fibre65.
Your current line cannot take the FTTC version. You'd need a new installation for FTTP.
The FTTP version is data only. No phone line.
https://new.talktalk.co.uk/broadband/fttp
There are Faster FTTP speeds than that - phone them and check that you can keep your number, to use a telephone using VoIP.
Yes it involves changes outside and in your property. The usual master socket would become redundant.
Daryl
Message 7 of 48
thanks for the info, so is Fibre 65 classed as full fibre and involve Openreach coming out to put whatever on the outside of my property.
Message 8 of 48
That is only an ESTIMATE,  @Daryl.
What you are currently getting is all that your current line can manage on FTTC.
If you installed Full Fibre, that would mean different speeds on different infrastructure. Not relevant to the potential of your CURRENT line.
Your FTTC line can't be magicked up to the higher speeds.
Actual speeds are only confirmed when the order goes through. Everything else is an estimate.
Daryl
Message 9 of 48
slighty confused now.  if i was to sign up as a new customer, looking at Fibre on the TT site, putting my postcode, house number in, i get told on fibre 65, that i would get a minimum guarantee speed of 55mbps??? so what can i get speed wise please going forward.
Message 10 of 48
No, fibre 65 just removes the 40Mbps cap so if your speed isn't already 40Mbps then you'll see no speed increase. Future Fibre will give you faster speeds if it's available to you - Full Fibre Broadband | FTTP Checker & Provider | TalkTalk
Daryl
Message 11 of 48
ok, so If i upgraded to Fibre 65, would that involve something else being installed with an increase to speed?
Message 12 of 48
Ok thanks. Unfortunately there isn't really much that we can do to improve your speed. As the speed is above the guaranteed minimum we can't raise it to Openreach as a fault
Daryl
Message 13 of 48
phone line is working ok.
Message 14 of 48
@Daryl, have you checked the results in My Connection (via Service Status Dashboard)?
That will show you a graph indicating what you are getting AND the minimum guaranteed for your actual line.
Mine currently looks like this:
Any other speed promises are averages based on a broad customer base, not necessarily accurate for your particular line.
Message 15 of 48
Is your telephone service working OK, any noise on the line?
Daryl
Message 16 of 48
the router and phone line are connected into the test socket.  how would i beable to get the speed of 35mbps that is suggested on your site, sky, BT etc?
Message 17 of 48
OK thanks. The speeds you are getting are above the guaranteed minimum, do you just have the router connected at the moment?
Daryl
Message 18 of 48
im getting download speeds of about 12.5mbps and upload about 4.7
Message 19 of 48
Thanks Daryl. There have been no further speed increases over the weekend. What sort of throughput speeds do you get?
Daryl
Message 20 of 48
as requested
