Can't log onto my account, webmail ok so not a password problem
sure2watch
Message 4 of 4
When I try to log onto my account the screen goes to the boxes for email and password and then disappears in less than a second leaving a blank white screen. So no time to complete the log in details. I can get to my webmail ok though but whether this is relevant is unclear.
Can anyone advise why the log in box details just disappears please and how I can correct. I have already been able to change my password as the first step of log in problems, but this has made no difference.
HELP please 😥
3 REPLIES 3
Message 1 of 4
is your version of Edge fully upto date?   we issues like this when updates are not accepted Safari is another one which has the same issue.
sure2watch
Message 2 of 4
Wow, that worked using Chrome. I always use Edge so I don't know why I can't get in using that, but at least Chrome works fine. Thank you. If you have any ideas as to why Edge won't work I'd appreciate it. I checked and although Adblocker is in Edge it is switched off.
Many thanks
Clive.
Arne-TalkTalk
Message 3 of 4
Hi sure2watch
Can you try using a different browser, and also disable any ad blockers for our site.
Thank you.
