on 09-04-2024 04:06 PM
Please could I have the wifi optimisation disabled on my router? The fact that the channel keeps changing means my network is not-working
Tuesday
Can I just check how's the connection been since your last post?
on 24-04-2024 06:56 AM
How's the connection been since your last post?
on 19-04-2024 08:05 AM
The product team have turned it off as requested, apologies for delay
on 19-04-2024 07:58 AM
Huh? What D-link extenders?
For the 5th time now, please can you arrange to turn off wifi optimisation?
That's all that I'm asking for. Why is this so time-consuming?
Just like in this thread: https://community.talktalk.co.uk/t5/Broadband/WIFI-OPTIMISATION/m-p/3035923#M864885 - please turn off wifi optimisation - you have 24 hours before I take my money to another ISP who won't mess me about.
on 19-04-2024 07:16 AM
OK, the feedback I've received says that some of the interference is being caused by the d-link extenders but I'll pass on your latest comments
on 18-04-2024 04:34 PM
Sure, I have 2 routers connected via wifi (one is the TalkTalk router, one some Asus one), each also has devices connected to the LAN.
The 2 routers are set so that the TalkTalk router uses channel 44, serves the wifi connection and does the dhcp for both routers.
The Asus router is configured as a wifi bridge, so uses channel 44, and connects to the TalkTalk router's SSID.
When the TalkTalk router is behaving correctly, (i.e. using channel 44) every device be it wifi or wired can see every other device.
When the TalkTalk router randomly changes channels, the Asus router can no longer communicate to any device (except the one wired into it).
Therefore, I need the TalkTalk router to stay on channel 44 and everything will be working 100%. I don't like having to log into the admin section and set it back to 44 on a daily basis.
on 18-04-2024 02:51 PM
Hi evilnick,
Could you explain exactly what you mean when you say that it breaks your network, what exactly happens?
on 17-04-2024 02:53 PM
OK thanks for trying. I'll pass this back to our product team
on 17-04-2024 12:29 PM
Sure, it always does the same thing:
Power off the TalkTalk router, leave it 5 mins, power back on
It will use the channel that I have specified (44)
Within 24 hours, it will switch to another channel, which breaks my network
At that point I can either set the channel back to 44, and wait for the router to disobey and set the channel to something else. Or reboot and then wait for the router to set the channel to something else.
This is the reason I have asked for the wifi optimisation to be turned off, as I believe that this is the reason the router changes channel when it should not do so.
on 17-04-2024 06:38 AM
Hi evilnick
Apologies for this.
Could you try rebooting the router and then retesting again?
on 16-04-2024 04:15 PM
It's not a good thing when you're trying to use a wireless bridge, and so NEED the channel to stay as what I have set it, 44.
on 16-04-2024 03:54 PM
It will be wifi optimisation that's causing the channel to change but this is usually a good thing as wifi optimisation should choose the best channel at any given time. We ask that you reboot the router because it may be something else that's causing the problem with your network
on 16-04-2024 03:14 PM
Chris,
The issue is that regardless of how many times I set the channel to be 44, this will change within 24 hours. Something outside of my control is changing this, and according to the many posts in this forum, apparently this is known as wifi optimisation. And is a setting that only TalkTalk can change.
Therefore, I require the wifi optimisation to be disabled on my connection.
Switching the router off for 5 minutes has 0 effect on this.
on 16-04-2024 03:00 PM
Hi evilnick,
Could you switch your router off, leave it off for 5 minutes, then swith back on and monitor to see if you are then still experiencing problems with your network. Please let us know how you get on
on 16-04-2024 02:51 PM
It's been a week now, so please could someone let me know when you will be able to give me the service that I have paid for? I'm very close to cancelling my subscription.
on 12-04-2024 02:14 PM
No, that's fine, we'll let you know when we have more information
on 12-04-2024 01:50 PM
Hi there,
Is there any additional information that I need to provide?
on 10-04-2024 07:35 AM
Hi evilnick
I've asked our Devices Team to take a look at this for you and I will post back as soon as I have further information.
