PPTP VPN needs enabling on router
Nilnilnil
Message 11 of 11
My router won’t let me use my works VPN my IT department says I need PPTP enabling on ,y router
10 REPLIES 10
Message 1 of 11
Hi Nilnilnil
Message 2 of 11
Firmware is showing on the correct version for VPN, so I feel this is a router issue, I've another on the way to you so this can be ruled out.
Message 3 of 11
I left my router on but the light was off and disconnected. I have rebooted the router and it is back online
Message 4 of 11
i'm having difficulty connecting to the router, can you power this off when you can so we can see if we can connect.
Message 5 of 11
Yes my router is powered on but I am not home
Message 6 of 11
Hi Nilnilnil
Is your router still powered up?
Nilnilnil
Message 7 of 11
Thank you that is the model of router that I have. Would a talk talk support team member be able to alter my firmware on my router so I can use my VPN again
Message 8 of 11
Hi Nilnilnil
Thank you for updating your Community Profile.
I will need to make a change to your router firmware, when would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Message 9 of 11
Hi Nilnilnil
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
Skynet_TX
Message 10 of 11
Hi @Nilnilnil,
If you have the Sagemcom Wi-Fi Hub (which has a single LED, and a bronze colour behind the holes on the front) then this issue may be caused by the version of firmware that it is running, the support team here may be able to change the firmware version to resolve the problem.
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include :
  • Your name
  • Landline telephone number that your TalkTalk service is provided on (this is shown in ‘My Account’) OR your account number if you have Full Fibre with no landline
  • An alternative contact number
This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
