Router resetting itself
BJones1
Message 10 of 10
My router keeps resetting itself.
This message is appearing in the user log:
1981-01-01 00:00:10 [Alert][Alarm-Log] AlarmID:104514,AlarmLevel:Alert,The system in the active area is damaged and has rolled back to the standby area
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset unexpectedly, Terminal:OTHER
An engineer has been round and couldn't diagnose any faults with the line, but observed the behaviour described above. Could this be an issue with the router / firmware? I'm at a bit of a loss as to what to do next (the engineer was too).
9 REPLIES 9
Message 1 of 10
Thanks for confirming.
BJones1
Message 2 of 10
Thanks for the responses. Finally got through to someone who was able to help. Problem seems to have been rectified. No idea what the issue was, but it seems to be sorted.
Message 3 of 10
Hi BJones1
Do you still need help with this?
Message 4 of 10
Hi BJones1
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 5 of 10
It is listed as software version at:-
Dashboard > See Internet Settings > Manage advanced settings > System Info > Device Information
BJones1
Message 6 of 10
Where do I find the firmware version?
Message 7 of 10
s it running firmware V1.06 then?
BJones1
Message 8 of 10
Hi Keith, thanks for responding. I don't see anything relating specifically to kernel panic, just the log entries I posted appearing multiple times. If I Google the error code, all of the results mention kernel panic though.
Message 9 of 10
Is there anything about Kernal panic in the logs?
