TalkTalk wifi hub VPN connectivity issues via WIRED ethernet connection
justinium77
Message 5 of 5
Having obtained the TalkTalk wifihub I've been unable to connect to my workplace RDP (Remote Desktop Connection) from home through the Watchguard VPN via a wired connection.....although there is no issues when connecting wirelessly......which is most strange!
When connected via ethernet, I get the following error message: "Your computer can't connect to the remote desktop gateway server. Contact your network administrator for assistance."
I've spoken with a TalkTalk representative a few weeks ago who stated that TalkTalk refuse to provide VPN support, so would need to raise this with a member of my workplace's IT team - whom happily connected remotely to my pc in order to view the settings on the router.
Unfortunately, they couldn't find what was preventing ethernet connectivity....so, I've had no option but to raise with TalkTalk again.
The last TT staff member performed an internet test on my router and confirmed that it was working as expected and, after a bit of a wrestleing match, they agreed to send me a replacement Wifihub router; having set it up and plugging it all in, the same issue still applies so would seem that some settings need to be changed from the default factory state it arrives in.
To add to this, I've changed the  DNS settings to  (8,8,8,8) (8,8,4,4) which hasn't helped in any way.
The older HG633 router worked flawlessly with VPN; unfortunately the TalkTalk wifihub seems to be incompatible.
Just to reiterate, the wireless connection is fine.  It is the wired ethernet connection which doesn't work with VPN.
I've looked at all the other comments raised on this forum about connection issues via VPN on the TT wifihub but they all seem to point to issues wirelessly.  I seem to be the first person to raising the issue via a wired connection.
Can anyone help?
J.Pitaluga
4 REPLIES 4
Message 1 of 5
Hi justinium77
This is a strange issue, as Keith advises, the Hub works with multiple VPN clients and protocols.  A large portion of our own staff are using this hub and using VPN for remote working.
Have you tried a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
Message 2 of 5
There are no known issues with VPN connections over either wired or wireless connections with this hub. However, I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Due to the current Coronavirus situation, the OCEs are very busy and there will be more of a delay to get a TalkTalk response. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
Message 3 of 5
Hi Keith,
Yes, I would have hoped so...but it doesn't seem to be so straightforward.
And to allow VPN over wireless but not ethernet wired connection is most bizarre.
To answer your question, I have the Sagemcom wifi hub.
J.Pitaluga
Message 4 of 5
Of course TalkTalk allows the use of VPNs. Which WiFi hub do you have (Sagemcom or Huawei)?
