Talktalk not connecting to work VPN
Mohammed9
Message 11 of 11
Im starting to work from home from next week.
Today I received my home working PC from my employer but my internet doesn't connect to my work VPN.
The VPN connections is important, I can't do any work without it.
I have a Huawei TalkTalk Router.
I have no internet issues and my Ethernet cable for my work pc works too.
I spoke to my employer and it seems like the internet service provider has an issue with the VPN connection.
I need this issue solved as soon as possible.
What can I do?
MT
10 REPLIES 10
Message 1 of 11
Thanks for the update and I'm glad to hear this. I'm just sending you a short survey via a PM.
Message 2 of 11
yes, I did.
Before I actually received the replacement router, I was able to fix the vpn connection.
The issue was actually the Ethernet cable, it wasn’t the router or my work vpn.
One end of the Ethernet cable was broken, which I did not notice at first. But I got a new cable and the vpn works .
MT
Message 3 of 11
Hi Mohammed9
Message 4 of 11
Hi Mohammed9
Message 5 of 11
Sure,
how long will it take to arrive?
I need it as soon as possible.
MT
Message 6 of 11
Would you like us to send a replacement router for testing purposes?
Message 7 of 11
OK thanks. I can send another router out to test with, would you like me to arrange this?
Message 8 of 11
I have Huawei HG633
hardware version: H.1.01
It just says I was not able to connect to the VPN server .
MT
Chris-TalkTalk
Message 9 of 11
Hi Mohammed9,
Which Huawei router do you have? What happens when you try to connect to the VPN, do you get an error message?
Message 10 of 11
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
