VPN connection not working
IanFinch
Message 6 of 6
I've been trying to connect to my works VPN and the following error keeps appearing: A connection to the remote computer could not be established, so the port used for this connection was closed. This has worked fine in the past, but within the last week this issue keeps appearing. The VPN I'm using is built in Windows 11 and my router version is SG4K100136.
Any help would be greatly appreciated.
Thanks,
Ian
5 REPLIES 5
Message 1 of 6
You're Welcome 🙂
Message 2 of 6
Hi @Karl-TalkTalk
It worked like a charm and I was able to connect to my works VPN this morning.
Thank you very much for your help.
Thanks,
Ian
Message 3 of 6
Hi Ian,
firmware updated, please try the VPN and let me know.
IanFinch
Message 4 of 6
Hi @Skynet_TX
Thanks for getting back to me.
I appreciate the update and will await further correspondence .
Thanks,
Ian
Skynet_TX
Message 5 of 6
Hi @IanFinch,
That firmware is new, so it is likely this issue has been caused by your router upgrading to that version, SG4K100136 has been causing VPN issues for some customers. The support team here should be able to fix this for you when they are back tomorrow, they will either need to update some router settings, or change your firmware to a slightly different version.
