WiFi not working
TeresaM19
Message 12 of 12
Wifi is not working and it failed to reset after switching it off overnight.
I am doing online-learning and need a reliable broadband connection.
Furthermore, I'm not sure how old my router is, and if I need a new one.
Teresa Meakins
11 REPLIES 11
Message 1 of 12
Hi TeresaM19
I'm so glad to hear that this fault has been resolved 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 12
Many thanks, all working fine now
Online Chat clarified what the problem was.
Hopefully will last for a long time
Teresa Meakins
Message 3 of 12
Hi TeresaM19
Openreach have now closed the fault as resolved and the line test is clear.
Is everything working ok now?
Message 4 of 12
Hi TeresaM19
This fault is still with Openreach, there are no additional updates at the moment.
I will keep monitoring.
Message 5 of 12
Hi TeresaM19
No problem. I will keep you updated here.
Message 6 of 12
Many thanks and hope it will get sorted soon 🙏
Teresa Meakins
Message 7 of 12
Hi TeresaM19
Thanks for confirming this.
I have escalated this fault over to Openreach to be investigated by a line engineer (externally)
I will continue to monitor for updates from Openreach and I will post back on this thread.
Thanks again.
Message 8 of 12
Always the Master Socket
Teresa Meakins
Message 9 of 12
Hi TeresaM19
Where do you normally connect the router? At the master socket or at an extension socket?
TeresaM19
Message 10 of 12
The router is connected as normal
Teresa Meakins
Message 11 of 12
Hi TeresaM19
I've completed a line test which has detected a potential fault. Is the router connected at the test socket at the moment?
