Connection to work shared drives on laptop
Stephen1986
Message 17 of 17
Since getting talktalk, or more to the point, the eero routers, I can or connect to my work based shared drives. What I can do is connect my router to my phone via ethernet, a docking station, and usb c to the phone, and then use my mobile as a hot-spot, and the drives work. Can someone please tell me what settings are preventing the WiFi from the router itself from allowing access to my drives. I have seen similar posts, and nothing from those worked. The only exception, which I haven't tried, is a replacement router.
16 REPLIES 16
Message 1 of 17
The wifi hub is suitable for a FTTP connection, and However this is not WiFi 6, but full speeds can be achieved.
Do you want me to send this ?
Message 2 of 17
What is the speed limit of the WiFi hub? It may be the only option.
Message 3 of 17
I have, from all that I can find, disabled anything and everything related to protection. All I get to is as long as something else provides the WiFi aspect of the connection, it works. I may need to look at the WiFi hub then.
Message 4 of 17
We can swap out the Eero for the WiFi Hub if you want to give that a try.
Message 5 of 17
Have you disabled all of the protection services on your account and on the Eero. You also don't have to use the supplied router, TT may replace with a HUB2 if you are having these issues but you can also buy your own.
Also connecting via Wifi or ethernet should not make any difference assuming they are using the same IP network.
Stephen1986
Message 6 of 17
A few people in my work have the same issue with the same, what appears to be, more legacy equipment/older servers. It has to be something to do with modern protection/settings on newer routers. I can connect an old borrowed slow router via ethernet to the eero router, and just let it pass through, and it works. Again using my mobile phone on hot-spot via usb c to ethernet to the router works, just not the WiFi from the router itself, and my old talk talk package before getting the eero routers worked. And yes, IT were not helpful in work. Would rolling back firmware on the eero help/is it possible?
Message 7 of 17
If some connect and others do not I can’t see how this is a TalkTalk issue and maybe coincidence that this has occurred. Doesn’t sound like your IT department are being much help but not sure the help required is here. Don’t think there are any special settings required on your local router as it’s certificate based authentication and IP-HTTPS IPSec and IPV6 I believe. All part of Windows.
Message 8 of 17
The shared drives are located at my workplace. It's odd that a couple of the shared drives work but others don't. When I asked IT in work they said some are possibly configured differently, but couldn't help with my issue, as it resides in the router settings it seems. I access them through the workplace direct access.
Message 9 of 17
I connect my laptop at home through the work's direct access, to access the drives at my workplace.
Message 10 of 17
are the shared drives on your own internal network?
mrwrighty
Enlightened One
Message 11 of 17
Are you saying that your work computer shares are in a remote site and you used \\<public ip of remote location>\network share. You say you are not using a VPN so can you explain how you connect.
Message 12 of 17
Hi, I had high hopes for this as it was on. Turned it off and still stuck.
Message 13 of 17
Also the message I get is 'an error occurred while reconnecting DRIVE LETTER to DRIVE LOCATION. The network path was not found. The connection has not been restored.'
Message 14 of 17
Hi, I don't use a VPN. Every protection setting seems to have been turned off, not sure what else I can do / what would be blocking these drives.
Message 15 of 17
Hi stephen1986,
Do you use a VPN? If so, which VPN client do you use?
mrwrighty
Enlightened One
Message 16 of 17
Do you have Scam protection enabled on your account. I think this really screws around with VPN and remote access stuff. Make sure its turned off on your account.
