All 4 error 4102-render-decode
turnip22
Message 3 of 3
Hi, All 4 Player is not working on our Humax box. The menus work and adverts play but then the actual program alway fail with error 4102-render-decode.
ITV player is always fine.
Software and apps are up to date and power cycling doesn't help..
Component software 3.8.70 (951eeb)
I can't remember it working since before we switched ISP to Talk Talk and the box branding got changed.
turnip22
Message 1 of 3
Maintenance Mode Software Reset did not resolve the issue.
Factory Reset (Keep Recording) thankfully did.
Message 2 of 3
All4 player is independent of your ISP and will be unaffected by the switch to TalkTalk.
You could try a maintenance reset for your box model and see if that helps.
Using Maintenance Mode - YouView Support
