Bluetooth connection
Mags12411
Message 6 of 6
Can I connect my Bluetooth hearing aids to my TV Hub
5 REPLIES 5
Message 1 of 6
Hi @Mags12411
Did you have any luck with this ?
Message 2 of 6
With your device in pairing mode, go to :
Home button > Settings Cog > Remote and Accessories > Add Accessory
This will then scan for bluetooth devices.
Message 3 of 6
Thanks Karl, but how do I do it - you haven’t given me any instructions
Message 4 of 6
You can connect some bluetooth devices to the hub, I've connected headphones to this, but I don't know if this will allow your hearing device to connect.  You can still give it a try, it won't break anything.   Do let us know if it works or not.
Message 5 of 6
I'm pretty sure that you can't.
Have you checked under the accessibility menu on the remote?
Bottom button on the right brings up the menu
If it's not an option then it's not available. I can't check as my box is not currently hooked up .
Remote control functions can be found here.
https://community.talktalk.co.uk/t5/Articles/TalkTalk-Remote-Control-Guide/ta-p/2204370#:~:text=Rese....
