ITVX on my TV hub
ToeKnee1
Message 17 of 17
How do I load the ITVX App onto my Talktalk TV hub ?
16 REPLIES 16
Message 1 of 17
@CarolynCooper have you read the advice in this thread given by @Karl-TalkTalk ?
If you still have an issue please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
Message 2 of 17
Message 3 of 17
How do I load ITVX onto my TV hub
Message 4 of 17
Glad it's now showing.
Message 5 of 17
OK its appeared now !
Message 6 of 17
If you select APPS then scroll down to look at all apps on the box, does it show lower down ?
Message 7 of 17
No have done a factory reset and the itvx app is still not in the featured apps
Message 8 of 17
No Problem 🙂
Message 9 of 17
Thanks doing a factory reset now
Message 10 of 17
You can reset as follows :
Home Button > Settings Cog > Device Preferences > Factory Reset
Message 11 of 17
No definitely not in featured apps - how do I reset the hub ?
thanks
tony
Message 12 of 17
If you press the Home Button, does ITVX not show in the list of featured apps ?
If not showing, you may need to fully reset the box.
Message 13 of 17
I definitely have a hub and fibre 65 not a box and the itvx app is not there
thanks
tony
Message 14 of 17
No I have a hub not a box and the itvx app is not there !
thanks
tony
Message 15 of 17
Hi ToeKnee1
Did this answer your question ?
Message 16 of 17
Which box do you have?
You mention the TV Hub and if that's so it's already pre loaded within Apps. If you have the hub you can quickly get to apps by long pushing the home button.
If you have one of the older YouView boxes Please see the pinned post at the top of the TV forum, here.
https://community.talktalk.co.uk/t5/TV/ITVX-and-TalkTalk-YouView-boxes/td-p/3010612
