TV Hub. How do I find my pin number. No box Not under batteries
Susank2
Message 3 of 3
Unable to find a pin number to use all programmes.  Have tried under batteries.   No box to look at  Google assist no help
Message 1 of 3
Hi @Susank2
Did the advice from fr8ys help ?
Message 2 of 3
During set up you are asked to input a pin.
If you don't the default is 1234 or 0000.
If these don't work, then you would have changed this to one of your own.
The only way to rectify this is to then do a factory reset, which will restore default or you can then input one of your own.
Hope this helps. Let us know how you get on.
